markanderson
What is TRBO can I pick up on scanner
trumpetman said:MOTOTRBO is a Motorola digital format. It can not be picked up by any scanner; you must add a discriminator tap to your scanner and run the data into a program called DSD (Digital Speech Decoder) to decode the audio on your computer.
KidClerk said:Wouldn't the proper terminology be to say that scanners can't decode MotoTRBO? They can "receive" or "pick it up", but cannot decode it into an audible format that we can make sense out of.
... If you wish to hear MTBO you will need to be authorized user of a system that is on MTBO. The only way that you can decode this is by buying a expensive computer program and hooking your scanner up to a computer. Most people do not want to do this and cannot afford this.
W9NES said:At the present time to this day there are NO scanners on the market that will decode MTBO. If you wish to hear MTBO you will need to be authorized user of a system that is on MTBO. The only way that you can decode this is by buying a expensive computer program and hooking your scanner up to a computer. Most people do not want to do this and cannot afford this.
DSD will not display color codes, radio IDs or talkgroups. It only demodulates audio. If you need to find color codes, time slots, talkgroups and radio IDs you need DMRDecode.
So the Software Defined Radio I built out of a old XP computer, a $15 E4000 TV dongle, and using DSD a FREE piece of software, that has NO scanner hooked to it and can decode MOTOTRBO can't possibly be working since it's not expensive and doesn't have a scanner hooked to it.
I'll have to remember that I can't possibly be hearing traffic on that from MOTOTRBO systems as I'm listing to such a system.
Just because you haven't researched a way, doesn't mean there isn't a way...
