I just wanted to get some opinions on using a tree as a mast for an antenna. Assuming that I can find some type of insulated material to mount it to the tree, would this be ok? Currently the antenna is mounted about 40 ft high on a mast attached to my house. Placing it in the tree would probably put it at about 80-90 ft high. A local tree climber said that he could climb one of the trees in my yard and hoist it up on a rope. This setup will only be for receiving. I figured that I'd also buy some LMR400 feed line. I am by no means an expert, so any comments would be appreciated. Thanks!
First you want to use a tree for a mast for your antenna, then you want to use expensive wire for your antenna.
Trees has many downfalls - such as the fact that they sway when the wind blows.
They rot and they can make even galvanized bolts rust when you install it.
Trees also make an excellent lightning rod because the tree is not a conductor and it sounds to me as if it is as tall as everything else in the neighborhood and your goal is to get your antenna above everything else without spending any money.
The only thing that i can say is that it isn't my antenna or my house.
I wouldn't want to live in your house though after you do it and the lighting comes down your coax and into your shack and takes a whole bunch of junk out with it.
You don't need LMR 400 for a receive antenna.
You can do the same thing with RG 6 quad shield or even some left over cable from the cable company - the silver stuff they use to go pole to pole - since they throw away lengths that are too short - under 100'.
That stuff makes excellent conductor for a receive antenna because it is very low loss and it is 72 ohm - which is no big deal because you aren't going to broadcast on it anyways.
