Trenton Police. Which Tones?
Frequency 155.0925. Call Sign KNCR 786. DCS Tone 115. Scan Chattanooga has it as 114.
Can someone tell me the correct one?
N8IAA
Fortunately, GA
What radio are you using to monitor? If it is a Pro-97, or 96, just program the channel in DC mode and see what comes up on the screen. That will be the correct tone.
Larry
Larry
Pro-97.
On one of my other threads for another area, someone said they could be using non-standard tones.
kf4lhp
Harrison, TN
Should be 114. I think I mistyped when I entered it on RR; I have 114 in the scanner which I can confirm is correct.
RR database has been corrected...
Thanks.
