Trip to Scottsboro
Fortunately, GA
#1
Haven't been to the UBC store in a couple of years. Coming in through Rome, GA on HWY 20 to AL 9 to AL 35 to Scottsboro. Is there anything P-25 along the route interesting to listen too, or, should I just use my analog scanner? It appears from the DB here that everything is still conventional.
TIA,
Larry
SAR923
#2
Everything is still conventional in that neck of the woods. A non-digital scanner will work fine.
Metrofire31
Western North Carolina
#4
NE Alabama/NW Georgia
Larry - I don't think you'll find anything between Atlanta and Huntsville that is P25. We frequently travel to Huntsville (Madison) along this route thru Rome-Ft. Payne-Scottsboro and it's all either VHF or UHF. There isn't really any trunked in that area. RR database will provide all the freqs you need.
