Troop L&K
KOK5CY
Afton, Ok
Has the freq's changed for the K&L troop's ? ....Normally i'll hear the Washington Co Trooper on state but there last few month's i havn't heard a single word out of the low band to the B-ville relay .
I'm close enough to the Pawhuska relay for K but nothing there either .
peterjmag
Tulsa, Oklahoma
Troop L went to the state 800 and everything is normal that I know of here in Troop K land. I'm might also add that I am high enough up that I don't use relays but just side 1 and side 2.
Secret_Squirrel
Tactical Communications Specialist
Pryor Creek, OK
After reading your posts on here for years, I've always suspected that you were high. I'm glad you've admitted that to us. Took you long enough. :)
