When I try to add a conventional freq into Win500 it always defaults to Scan List 1. The shortcut to add new freq does not work. I cant highlight the frame. I have to go to the All freq screen and add new to end. It always defaults to scan list 1. . . .
I suppose by "All freq screen" you're referring to the
All Objects tab.
What happens when you select the
CONV objects tab and then press
Alt+Ins or
Ctrl+Shift+N? Either of these shortcuts should create a new conventional object, either above the currently selected conventional object or at the end of the list of conventional objects.
This new conventional object is highlighted and does indeed default to scan list 1. It's a rather simple process to assign the new highlighted object to any, all, or no scanlist—your choice—using the scanlists checkboxes near the upper-right of the screen.
Seems to me that this is the way Win500 is intended to work—not a bug.
