biggysmalls0409
- Joined
- Nov 22, 2006
- Messages
- 11
I have 2 BCT-8 scanners.I wanted to be able to hook them to my pc and read what's in them and make some changes.Here's the problem:I bought and installed the ARC8 software.I bought the RadioShack brand RS-232 cable.I put the scanner in remote mode,hook the cable from the scanner to the pc,set the baud rate in both units and what I'm getting is that my computer is not "seeing" the scanner.The com1 port is enabled in the device manager on the pc.It says it's functioning properly.The scanner says "RMT" on the screen,and yes the scanner is turned on.,but still no luck.I even installed the ARC8 on my laptop,used a usb to serial port converter cable and still it won't recognize it so I think that it's something I'm doing or not doing with the scanner.Tried both scanners with identical results.I have the manual.It seems easy enough to put into the remote mode,but ??????????????? Oh yea,and just for the sake of a possible bad RS-232 cable,I exchanged it for another today and got same results.I'm out of solutions.
