Trouble installing ScannerCast
lzabka
I have installed ScannerCast as per the instructions in the email I recieved when my account became verified. However now I get an error that says the application failed to initialize properly. I installed it on another computer of mine and it worked fine, however that is not the computer where I would like to have it broadcasting from. The one I am having trouble with is running XP and the one I got it to work on is running vista. Any help would be appreciated. Thanks in advance
Luke
gmclam
Fair Oaks, CA
ScannerCast
Do you have the .NET environment loaded in the failed computer?
lzabka
How do I know if the .Net framework is installed. If its not how is the easiest way to get it done? Thank you.
Luke
KB0VWG
Updates
Luke
Need to make sure you have .net framwork in you add/remove programs folder. If its not ther you need to download it from microsoft. Go to your add/remove programs in your vista pc and more than likely its there.
73s
Michael
kb0vwg
