Trouble Reading Kenwood TK-7180
gip127
Member?
New Jersey
I need some help. I am trying to read a fleet of radios. They are all TK-7180. I cannot find a straight answer to which software to use. I tried every software I could find including:
KPG-89D
KPG-89DN
KPG-92D
In each of these software's I get the same error. "Check connection and COM port settings"
I am using a cable I have for the 5x20 series radios... Is this the proper cable?
Thanks in advance.
kd4efm
EL98 Florida
have you tried taking a RS232 cable, plug it into the back of the radio and reading it?
(DB25 to db9 to usb/bd9 port)
KPG-89D or DN is for the x180 series if it is not passport.
KPG-46, 46U, or 46XM is the mobile cable you want to use
What does the radio show when you power it up? ("SEARCHING..." mean PASSPORT)
Do you get anything when you do a "tool/transceiver info"
What firmware is in the radio when you press and hold the S and PWR ON (I think thats the key or the "A" key)
gip127
Member?
New Jersey
As far as access to the back of the radio, I do not have that. They are mounted in patrol cars and to get to the back would be near impossible.
The KPG-46 is the cable that I have. When the radio turns on, it goes right to the conventional channel it is set to. I do not know how to do a tool/transceiver info.
Will check firmware.
kd4efm
EL98 Florida
That's a NX-x00 OR a tk-5x20 (P25) you need 111DN or 112(p25) for that.
if there is a label it will be top center on the upper side of the face (run your finger along the top, if you feel a sticker,
chances are it's a NX radio., P25 sticker is to the far left above the power button.
