I’m not sure, it had been updating/working automatically for over a year and then I started getting this message (see above). I haven’t been able to update the library files for a month or so.Have you tried to update EZ Scan? Are you using the correct EZ Scan for your scanner model?
Also, the library updates into EZ Scan, not directly to scanner, you then copy the library to scanner after update.
I have version 3.40The latest TRX-1 application is version 3.40. Go to the Help tab and click on About Whistler TRX-1 Handheld Digital Scanner Programming System to check the version number. Some of the earlier versions had downloading problems. If you have an earlier version, go to the Updates tab and click on Check for PC Application Update.
I might try an uninstall/reinstallHave you tried to update EZ Scan? Are you using the correct EZ Scan for your scanner model?
I can't find the name of the App to uninstall it.That's not a bad idea. Try giving Whistler support an email or call, they are nice people and should be able to help quickly.
That would make sense as the problem arose out of nowhere.A note to crossnote--- I found that I had to remove the card from my scanner and use Windows to do a full format as opposed to a quick format in order to get my TRX to recognize the card again.
I'll take a look later, wifey has din din on the table.@crossnote make an archive of your programming by going to file and save config to archive. AFTER that go to the TRX-1 (I think you said you had the 1) folder in documents folder and delete the database folder contents, now try to download again. It is something with your computer/Internet connection as it just worked fine for me.
@MStep take a look at this and see if it helps... (applies to all the new WS/TRX scanners)
Just offhand is there anyway to update the files directly using the TRX without EZScan?
Right, I've successfully used EZScan for over a year. Just wondered if I can update the scanner itself using something like the zip code method, etc..You mean updating the database? No you must import from EZ Scan. I told you how to manually do it above.
Thank you, I'll try that tomorrow.Thanks for all your help N1GAW. I really like the sound and form-factor of my TRX-2, but it is quite a transition from Uniden's Sentinel. Some of my issues have been related to crossnote''s as well. A note to crossnote--- I found that I had to remove the card from my scanner and use Windows to do a full format as opposed to a quick format in order to get my TRX to recognize the card again.
