Trump Protests
#1
This is the 3rd night in a row of Trump protests in Tampa. Listening to 10-016 on Hillsborough EDACS and it sounds pretty volatile. Unitrunker is actually showing they have patched 10-016 and 03-141. The patch ID is 15-155.
ChrisABQ
Albuquerque, NM
#4
Hey Homeboys, were you successful in tapping digital radio traffic from your BCT15X discriminator tap to be able to monitor provoice through DSD+? OR, is the provoice listed analog?
#5
Yeah, I tapped the BCT15X and it works on ProVoice with DSD+. But I have Unitrunker running on 2 dongles, one for both control channels, and the other for voice following. Then the voice from the 2nd dongle is fed into DSD+ to listen to ProVoice. So I don't actually use the tapped BCT15X for ProVoice.
