Trunk88 Latest Version Download?
gr8rcall
Alamance County, NC
Okay guys,
I can't find the latest version of Trunk88. I used to have it, but my computer crashed, and it was lost....
I need the latest version that works in a 64-bit OS! It's Windows 7!
Can someone direct me to the download location?
I tried the link on the Wiki, but I can't find anything, as everything looks old.
Here's the link I used:
Index of /~phoenix/wap/TRUNK88
Also, that site doesn't look like the site I used before.....has it been changed?
If the latest download (64-bit compatible) is on there, can someone tell me which one it is?
Im probably just overlooking something. :roll:
Any help appreciated!
gr8rcall
Alamance County, NC
Thanks!
Can you still direct me to WHICH download it is?
I see 4.88k, but it says 32-bit. Will that 4.88k file still work?
I need someone to confirm which is the LATEST download that WORKS on 64-bit!
I don't want to do the trial and error thing, because I don't want to have any 32-bit on a 64-bit OS problems!
Glad to know that's the correct site, though!
As I mentioned, the site looks old. Just a list of files, no graphics or anything, and a white background. I do view the site on an Ipad, maybe that has something to do with it. Or is it the site?
Do you see it as a regular site, with graphics and everything?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
488k is the last version.
I still run XP so you'll have to wait until somebody else responds.
mdulrich
Van Wert, Ohio
The 32-bit version will work fine on a 64-bit machine. AFAIK there is no 64-bit version of the software.
Mike
Dave - I have no reason to think otherwise. The Motorola trunking format hasn't changed much so there's little need for changes. The two recent alterations were a new standard bandplan for 851 Mhz and Smart X. Unless RR.com changes the DB download format, I don't see any pressing need for changes. I can't speak for Andrew. However, I see him check in here about once a week and I'd hate to see your question hang for a long time. In short, don't take the lack of a new release as a lack of support.
slicerwizard
Toronto, Ontario
Hm, last discussion on the TRUNK88 forum was four whole days ago. So yeah, totally unsupported these days.
Delivered-To: mailing list TRUNK88@yahoogroups.com
Date: Tue, 09 Apr 2013 19:44:43 -0400
Subject: Re: [TRUNK88] Problem starting up Trunk88
The site is not sending valid SysID markers. You can work around it
by setting the System Type value properly in TRUNK88.CTL (it should be 31)
Let me guess - this is more of Motorola's SmartX crap...
At 09:15 AM 4/9/2013, Joe wrote:
>When ever I put the control channel audio into the program via the
>microphone jack the program does not decode anything? I am missing
>something?
>Screenshot
><http://farm9.staticflickr.com/8526/8634852802_f070ca8f45.jpg>
Eh, make that two minutes ago...
Date: Sat, 13 Apr 2013 18:38:58 -0400
Subject: Re: [TRUNK88] Radioshack Pro-2096 & Uniden BCT 996T
You need to feed the program with control channel *audio*. The
normal procedure is to use a discriminator tap to access unfiltered
audio and feed that to your PC's sound input, but you can try using
audio from the headphone jacks on your radios as well. You'll need
an audio patch cable - the ReadMe file shows what's required.
At 06:26 PM 4/13/2013, Shaun Maclaughlin wrote:
>Hi There, I am new to this program and I would like to start
>decoding my areas trunk system but I have no idea where to begin. I
>have both a Uniden BCT 996T with a Serial to USB cable and a RS
>Pro-2096 with the PC Interface cable.
>I am running Windows 7.
>Can someone help me get this running?
>Thanks :)
