Trunked Priority Scan
gibson135
Denver, CO
Just want to double check something here. With a Trunked System on BCD436HP, you don't enable in the main menu but only in the individual system options. Then after than, since priority scan will not be able to be enabled, even though the "pri" and inverted P are not on the screen, they are still priority channels (and I assume still checked at the interval set in the priority options).
So they are still a priority even thought you get the error that says "Priority Scan, No Channel" and there is nothing on the screen saying it is?
UPMan
In Memoriam
Arlington, TX
On trunked systems, priority channels are checked continuously using the subaudible data in every channel, not at an interval. If you set a trunk system to have priority, then it will apply priority. The error you see is related to conventional channel priority and does not have any bearing on trunked systems.
gibson135
Denver, CO
Thanks. Didn't know that with the time interval. The other part, is this going on with the Trunked Systems even though the "PRI" and the other P aren't there? So those are only to show the conventional priority is enabled? Even after trying a few things I'm not seeing those on the screen.
Voyager
Correct. The PRI and PRI key is only for conventional.
ofd8001
Louisville, KY
There are a couple of priority scanning "things" with the x36 scanners. They are two separate and distinct creatures when it comes to conventional and trunked priority scanning. One has to look very closely at the the wording and it takes some getting used to. I'll summarize a little below, but there is a detailed explanation in the manual starting on page 50.
"Priority Scan" applies to conventional systems. "Priority Scan" is enabled in Sentinel by editing the applicable profile (Miscellaneous>Priority Scan Mode either DND or Priority). Then in the Favorites List Editor, desired priority conventional frequencies (channels) are marked with P-Ch On.
In "Priority Scan", when the scanner stops on an active non-priority conventional frequency (channel), it will periodically check those priority conventional frequencies (channels) for activity. If there is activity, the scanner holds on the priority. When checking for a priority conventional frequency (channel), it is pretty apparent as there is "skipping" in the non-priority transmission.
For a trunked radio system, it is called "Priority ID Scan". Upman described how this works. "Priority ID Scan" is something set up entirely within the Favorites List Editor for the applicable system. In the applicable system, go to the Options tab and choose On for the Priority ID Scan and then selected the desired Talkgroup IDs by turning P-Ch On. Priority ID Scanning of trunked systems is not as obvious as Priority Scanning of conventional systems. There isn't that interuption.
A couple more things to note:
If you are scanning both trunked and conventional systems and the scanner is holding on an active convention frequency, it does not look at a trunked system for active talkgroups that are set for priority.
Conversely, if holding on an active talkgroup in a trunked system, the scanner does not check for an active priority frequency in a conventional system.
If you have turned Priority Scan On (the one for conventional systems), the scanner has to have "access" to at least one conventional freqiency (channel) marked as priority. If it does not have that "access", then the message "Priority Scan. No Channel" is displayed. "Access" to priority conventional frequencies (channels) can be denied in several ways: The applicable FL turned off, system/department/channel avoided and so on.
If you see that "Priority Scan. No Channel" message, you can press System to resume scanning and the scanner will re-set Priority Scan to Off. To go back into Priority Scanning you have to restore access to priority channel(s) and turn Priority Scan back on to either DND or Priority.
gibson135
Denver, CO
Thanks a lot for the detailed description! That helps a lot, really clears things up tremendously.
UPMan
In Memoriam
Arlington, TX
One other scenario: if you are on one trunked system, it also will not check for priority in any other trunked system. It can only check in the system it is currently monitoring.
