Trunking and EVX-R70 reset/reboot (through rear MAP)
k7plt
#1
I have submitted this question through Vertex Standard support, and am awaiting an answer, but
thought I would give a shot here too.
Actually 2 questions . . .
1.) I notice that Vertex supports LTR trunking through several products (ie., 420A, 2200, 450 & 4x00 series),
yet they have no trunking repeater products ? Are we supposed to use Motorola ?
2.) The EVX-R70 repeater supports 16 channel slots . . . Why do this when only one channel (of 16) can be
accessed at a time, and to change it (through MAP port) requires a reset/reboot ? ? ?
