Trunking Recorder 3.3.5096 released
scannerbox
michigan
Trunking Recorder version 3.3.5096 has been officially released.
Trunking Recorder is a Windows application for recording/importing audio from trunked radio systems monitored by Unitrunker or SDRTrunk. Trunking Recorder will save all the recorded calls and allows searching and playback through a web browser. Trunking Recorder will also queue up recorded calls so you never miss any activity when multiple talkgroups are active at the same time.
The full list of changes in this release are
  • Updated third-party libraries
  • Added Duplicate Call checking to SDRTrunk imports if Trunking Recorder Call uploads are enabled.
  • Fixed issues that could cause calls to get skipped on the web interface during a call list update.
  • Changed the date selection box on web interface to not show the current date by default. This should make it clearer that it's not searching just today's calls by default.
  • Added search box to Favorites, Call Uploading, Streaming, and Call Notification configuration menus (Will search Target Label, Target ID, and Target Tag).
  • Added Target Tag column to Favorites, Call Uploading, Streaming, and Call Notification configuration menus.
  • Added option to specify an alternate database folder for the SQLite database files (Allows for database file to be stored locally and audio files to be on a network share).
  • Added option to turn off purging of unused Systems, Sites, Talkgroups, and Users.
  • Added option to blindly trust the MS SQL Database server certificate (useful for self-signed certificates).
  • Increased call purge timeout to 90 seconds when using MS SQL Database server.
  • Added "unknown" talkgroup and radio user search options. (Displays groups and users with blank or "Unknown" values)
  • Added Target and Source Tags to Custom MetaData.
  • Fixed issue when using MS SQL database where email notification addresses wouldn't save correctly.
  • Fixed issue when using MS SQL database that prevented searching for Talkgroups.
  • Added support for automatic Night Mode when browser prefers a dark theme.
  • Call Upload API now supports older versions of ISO 8601 date format.
  • Fixed web interface search issue when using MS SQL database server and the SystemID contains a hyphen.
  • Fixed web interface user authentication denied issue when using a HTTPS server with HTTP disabled.
  • Fixed web interface search issue that caused some calls to not get listed when selecting a date that occurred with daylight savings time starting or ending. (Note: Call searching is done based on the server's time zone and not the local web browser)
The new version can be downloaded from
https://www.scannerbox.us/TrunkingRecorder/
