Trunking talkgroup normal scan
theremnant
I just got a G4 and when I change the knob position it says "Trunking talkgroup normal scan". Is there any way to keep it from doing that? I looked but could not find a setting on the unit itself or the PPS that would silence that.
Also, there is a hissing noise independent of the actual volume setting when a transmission occurs. Is this normal?
IAmSixNine
Dallas, TX
For the Trunking Talkgroup Normal Scan. You can disable that.
Go into the number 5 slot, Zone and Channel Setting.
Once there double click the correct Knob you want to modify. For example, Zone 1 Knob 1.
Once that window openstowards the top you should see a Voice Prompt drop down menu.
Change this to None.
As far as a hissing noise i dont notice it on mine but if its super quiet and im close to it yes i do.
