Looks like you programmed by frequency types which are the higher numbered scanlists. That may have activated the lists in the 150-200 range. You should label the scan lists with what you put into them by clicking on the scanlist name in the general settings tab and chnging the name.
You might also find it easier to use the PREFERRED method for programming, to give you better control over what exactly you add to each scanlist.
