TRX - 1 programming
Minnesota
#1
Has anyone programmed the whistler TRX 1 scanner by the preferred way, not the zip code way. I have the program up, but can not figure out the program. Could there be a step by step programming instructions, that someone might be aware of.
Thx, Ron
buddrousa
NW Tenn
#2
Pick your state.
Pick your county.
Pick your Frequencies / Systems / Talkgroups
Pick your play list
Import
Do not forget to turn on your playlist.
bernietr
Burnsville, MN
#5
eTRX-1 and TRX-2 beside Uniden 436 and 536
What is the more sensitive radio?
Are there distant sites that pick up better on one or the other?
-Tom B.
Minnesota
#7
trx1 changing frequencies in county
If you want to add or take away a frequency within the county you have programmed. how do you do it.?
The SKIP button, you can temporary get rid of a frequency if you hit it, to eliminate it all together, what is the process?
Wondering if there is a way to set the range?
