TRX-1 Spectrum Sweeper
Applied 3.6 update,Spectrum Sweeper working,but when it finds a DMR channel,it doesnt look like its decoding.Anyone else have input on this matter?
markgrutz
Ellicott City, Maryland
Its working,but when it finds a DMR channel,it doesnt look like its decoding.Anyone else have input on this matter?
I just installed the new firmware and was playing with it. As Wendy said it seems like the squelch seems to be really important here. I was missing most transmissions when the squelch was in the "recommended" zone, and catching most of them with it turned all the way down. I have tested on all my programmed DMR frequencies, and it picked them up and decoded them about 75% of the time. The remainder I am going to assume is proximity, or squelch or something causing the issue.
Just my quick in house test.
just
Im just glad Whistler fixed the Spectrum Sweeper function,and very fast I might add.At least one company listens to its fans,Go Whistler!
MichaelBhere
After updating the PC app and CPU, did you update the DSP? I updated all 3 and seems to be working for me.
update
Yes i updated all.It stops on DMR frequencies but I havent seen it decode yet using Spectrum Sweeper.
