k2asp
1. At present the backlight comes on at "turn on" time, then goes off when the scanner starts functioning in the scan mode, and comes on for only a second or two when the scan stops on a communication. How do I set up the scanner so that the TRX-2 screen backlight is lit at all times when the scanner is powered on or at least at all times that a communication is being received?
2. Using the brief instructions in the User Guide I have not succeeded in varying the light level of the backlight at "turn on" time or when the scanner is in use. Am I not doing something that I should be doing?
