Trx-2 programming software
ZS6RES
Anyone know a way to move, insert cut/paste in the programming software esp. in the conventional area or are you stuck with adding new channels below.is there a data file created that one can work on.
TAbirdman
MO
you can click on the header ( Alpha Tag, Frequency etc) and it will sort the column A-Z or Z-A for example.
AggieCon
Texas
No, this is not possible. The data files are not supposed to be edited. It is quite frustrating. There should be other threads around here on this very topic.
Wackyracer
It doesn't matter what order they are in the database as someone else said they can be sorted by ANY of the individual columns just by clicking the label at the top. This includes playlist. so you can find what channels are in each playlist or add them to a playlist or make a new playlist by using a number that has not been used yet (not sure what the limits are on it 1-xxx?
