TRX-2 Windows 10 drivers
dmaria
#1
I have a TRX-2 that I have updated succesfully several times. Starting last Sunday (Jan 1st) I could not get Windows 10 64bit to recognize the scanner. After looking around today, I found the drivers in the device manager had reset to a generic usb serial port. When I tried to update it to the Whistler TRX-2 driver Windows would not install it because the drivers were unsigned.
Has anyone else had this problem? Did Whistler forget to update their drivers? Will I end up with another orpahned scanner like the GRE 800 (It has the same problem)?
Dave
MO
#2
Open EZScan and if you haven't already, update it to the latest version. When done, reboot your PC and THEN connect the scanner to the PC and try it.
dmaria
#3
I a bit of a nut when it comes to updating software. I'm always up to date. EZ Scan wasn't the problem. The drivers were.
Whistler tells me that the drivers use a generic USB serial driver and thus do not need a signature, so do not install the driver that Whistler provides because it will complain of not being signed.
Turns out the biggest problem was the scanner itself. After pulling out the 3 hairs I had left, I finally unplugged the power to the scanner and it started working.
MO
#4
whistler did an update on EZScan for windows 10 to load the "driver". So you don't have to get around the driver issue that you have to do on Windows 8 and 8.1. That is why I suggested to update and reboot your PC.
Yes, never have the unit powered up or even connected to 12 volts when connected to the PC.
