Trying to listen to burnaby RCMP/VPD
#1
Hi its been over 10 years since I had a scanner to listen to Burnaby RCMP/VPD. My understanding is theres digital scanners to listen again. Any recommendations on a handheld scanner. Also i think i read next year they will be using a different system so I would prefer to buy a scanner that is capable to listen in when that happens. Any help would be appreciated. Thanks
#2
So i read the uniden bcd436hp handheld should be able to listen to burnaby and vancouver police but then a few people said all lowermainland police are encrypted and wont be able to listen. Pleae help Im confused.
#4
So the 436hp with $50 add will work. If they become encrypted sometime soon I'm guessing the scanner would be useless for listening to burnaby/vancouver police.
In the 'patch
#5
Correct. Once Ecomm builds and moves to its 700MHz P25 phase 2 system they will most likely be encrypted. If they encrypt you will be out of luck listening to th
#6
kayn1n32008 any idea wen there moving to 700Mhz. I think I saw it was for 2017 but just want to make sure. U also mention 'most likely' be encrypted. Is there a possibility they might not encrypt.
In the 'patch
#8
No idea.
Although nobody knows yet, 99.999999% chance RCMP will be 100% encrypted. They are replacing their analogue VHF system used through out the rest of the province, with a conventional P25 system and where it has been done, they are 100% encrypted.
Most likely VPD and all other municiple police forces currently using Provoice on the EDACS system will be encrypted as well.
