Trying to listen to burnaby RCMP/VPD
vancity604
Hi its been over 10 years since I had a scanner to listen to Burnaby RCMP/VPD. My understanding is theres digital scanners to listen again. Any recommendations on a handheld scanner. Also i think i read next year they will be using a different system so I would prefer to buy a scanner that is capable to listen in when that happens. Any help would be appreciated. Thanks
vancity604
So i read the uniden bcd436hp handheld should be able to listen to burnaby and vancouver police but then a few people said all lowermainland police are encrypted and wont be able to listen. Pleae help Im confused.
vancity604
So the 436hp with $50 add will work. If they become encrypted sometime soon I'm guessing the scanner would be useless for listening to burnaby/vancouver police.
kayn1n32008
ØÆSØ
Sector 001
Correct. Once Ecomm builds and moves to its 700MHz P25 phase 2 system they will most likely be encrypted. If they encrypt you will be out of luck listening to th
vancity604
kayn1n32008 any idea wen there moving to 700Mhz. I think I saw it was for 2017 but just want to make sure. U also mention 'most likely' be encrypted. Is there a possibility they might not encrypt.
vancity604
This scanner is like $700-$800 so if they encrypt in 2017 thats alot of money for 1 years worth of use only.
kayn1n32008
ØÆSØ
Sector 001
No idea.
Although nobody knows yet, 99.999999% chance RCMP will be 100% encrypted. They are replacing their analogue VHF system used through out the rest of the province, with a conventional P25 system and where it has been done, they are 100% encrypted.
Most likely VPD and all other municiple police forces currently using Provoice on the EDACS system will be encrypted as well.
vancity604
Would the uniden bcd396xt be able to listen like 436hp. I could buy the 396xt for cheaper so im wondering.
