- Joined
- Nov 12, 2014
- Messages
- 17
- Reaction score
- 1
hey everyone,
just got my new BCT15X scanner in and trying to set up Indiana State Police Motorola type 2 re banded channel. i am not using any software, as i only need to input few channels, so all manual here. Heres what ive done in order and where i get an error, also note with the 15x it doesnt give me an option to select type 1/2 or hybrid, just "MOT"
program system>MOT>(named ISP)
ISP> EDIT SYS OPTION:
-------set number tag:1
-------id scan/search: id scan
ISP> EDIT SITE: (created site named ISP dispatch)
-------set quick key:1
-------set startup key:1
-------edit band plan>custom>band plan 1>"851.0250"(lower) "854.0000"(upper)
---------------------------------------->band plan 2>"851.0125"(lower) "868.9875"(upper)
-------edit frequencies-853.8625(primary channel for the town of MADISON INDIANA, JEFFERSON COUNTY)
ISP> EDIT GROUP:
-------set quick key: 1
-------edit channel>ISP dispatch>edit TGID>***i try to enter 4112 (dec mode was selected under "set ID format) and get "bad TGID" am i suppose to add the "." before entering "4112"? if i do that it becomes displayed as "i4112" and is accepted.
then i go to scan, and it displays "ISP DISPATCH---ID SCAN" however i let this thing run for 2 hours and i havnt herd even static.. also at the top of the dispay is showed a blinking "signal strengh?" icon? ive tried turing the squelch all the way down/ up and no difference.
also under "ID SCAN" it shows a "NFM" for 1 second, then a frequency "853.8750" is displayed for 1 second, and it just keeps cycling. what am i doing wrong here??
ISP> EDIT GROUP:
