SDRTrunk Trying to set up sdrtrunk
Szumi
I'm trying to set up sdrtrunk today. I was watching a youtube to help me. I keep picking p25 phase 2 and p25 phase 1 shows up. What am I doing wrong?
Thanks,
Szumi
flaw101
Fruit Cove, FL
I’m no expert, but maybe the control channel is telling sdrtrunk it’s actually a phase 1? Are you seeing the control channel active?
Whiskey3JMC
NI NI NI
Simulcastylvania, TE
Welcome to the RR forums. The system may be Phase-II CAPABLE but contain FDMA talkgroups (mode "D" in the RRDB). Can't know for sure since you didn't give us system specifics
Szumi
I've played around, if I select p25 phase 2 trunked phase one shows up. If I pick p25 phase 2 single channel that shows up as phase 2. I'm confused.
Szumi
I'm trying to set up for the system in michigan, kalkaska co to be specific.
Whiskey3JMC
NI NI NI
As I predicted in post #3, talkgroups in your county are Phase-I FDMA (mode "D") although the system is Phase-II/TDMA CAPABLE. You should be able to pick them up just fine with the programming as-is. You won't be able to switch the setting unless the county converts their talkgroups to TDMA (mode "T") & the change is submitted to the RRDB
