Hi,
I have 14.8 installed. It is currently configured for use with a BCD325P2. I'm trying to get it running with my SDS200 which is networked and on the same LAN. However, when I switch scanner type to the SDS200 the menu bar (Favorites Editor, Options....etc....) is grayed out and none of the functions of the software work; instead I'm greeted with that dandy Windows "screw you I'm not gonna work" ding...
My only solution at that point is to use End Task in the Windows Task Manager to close ProScan. If the solution is listed here at RR I'm not searching the forums correctly. Before I deactivate/uninstall/reinstall I figured I'd ask what I'm missing.
Thanks!
Thanks!
