Turnpike
BT
#1
I've been driving the turnpike regularly from Cleveland to Indiana, and then the toll road to Chicago. Since the IP system is now up and running, what towers would I need to program in to listen to the Highway patrol and turnpike activity the whole way? Are the maintenance forces still using the 150 MHz frequencies or did they move too?
Thanks in advance
BT
Northern Ohio
#4
Specific to your question the Turnpike Maintenance is very active on the following Talkgroups and Conventional frequencies. Also the Turnpike crosses the following counties so you should program MARCS-IP towers for these counties.
Talkgroup 51900 Oh Trnpk E Maint
Talkgroup 51905 Oh Trnpk W Maint
Conventional 159.165 Ohio Trnpk Maint
Conventional 156.195 Ohio Trnpk Maint
Counties Mahoning
Counties Portage
Counties Summit
Counties Cuyahoga
Counties Lorain
Counties Erie
Counties Sandusky
Counties Ottawa
Counties Wood
Counties Lucas
Counties Fulton
Counties Williams
BT
#7
Thanks so much everyone. I was going to ask the same question for the Indiana toll road on that board so if anyone here knows, feel free to chime in. Thanks again.
