TV Station Feqs?
enki042000
Lafayette,IN
There was a thread on here giving the freqs for the indy stations and the FCC website to look them up.I'm looking for WLFI-TV 18's freqs here in Lafayette.I went to the FCC website to look it up but no luck.What is the actual call sign for TV 18?-John
AK9R
Staff member
Super Moderator
Central Indiana
If the OP is looking for the frequencies that WLFI broadcasts on, the answer is both easy and complicated.
The simple answer is that you can go to the Radio Reference wiki and look up the TV station's channel number in the TV frequencies chart. The link is:
http://wiki.radioreference.com/index.php/Television_Frequencies
TV Channel 18 is allocated 494 to 500 MHz and the audio carrier is at 499.75 MHz.
However, after WLFI switches off their analog transmitter (sometime on or before February 17, 2009), two facts will come into play:
1. WLFI digital has been licensed to TV Channel 11. As a result of the digital TV transition, WLFI will cease broadcasting in analog on TV Channel 18 in favor of broadcasting in digital on TV Channel 11. You can go to this web site, http://www.rabbitears.info/market.php , to look up the digital channel assignments by either your market number (Lafayette is #170) or by the callsign of the station in question.
2. While you can currently monitor WLFI's audio signal by tuning your scanner to 499.75 MHz, after the digital transition, you will no longer be able to monitor their audio signal because it will be encoded in the digital broadcast signal. I am not aware of any scanners currently available that can decode the ATSC digital TV signal format.
On the other hand, if the OP is looking for additional licenses held by the TV station, that will require more digging. The WXX209 given by Mick is for a Broadcast Auxiliary Remote Pickup, not the actual television broadcast license.
W9NES
Indianapolis,Indiana
WRTV Channel 6 will also be off the air on 87.7 FM in the Indianapolis area when February 17,2009 happens.I got this direct from their Chief Engineer of the transmitter at the station
AK9R
Staff member
Super Moderator
Central Indiana
WRTV, because of it's long-standing license on TV Channel 6, has been able to promote the fact that listeners can hear the station's audio signal on their car radios. TV Channel 6 is allocated 82-88 MHz with the audio carrier on 87.75 Mhz. Even though the FM broadcast band is allocated 88-108 MHz, most FM broadcast radios will tune below 88 MHz. As a result, you can set your FM radio to 87.7 MHz and hear the audio from TV Channel 6. This has been true everywhere in the country where there is a TV station on Channel 6. This is not unique to WRTV and they are not doing anything out of the ordinary to make this signal available on people's car radios.
However, the transition to digital television changes things dramatically for people who have been listening to WRTV's audio signal on their car radios:
1. WRTV's digital license is on TV Channel 25 which is allocated 536-542 MHz. WRTV will go dark on TV Channel 6.
2. As I stated previously, there are no scanners, or car radios, that I know of that can decode ATSC digital television signals.
I am not here to promote Radio Shack or the products they sell, but they do have a small, portable television that can decode ATSC digital TV signals. This TV is can be operated from 120VAC or from its internal batteries, though one report I read said that the batteries will only operate the TV for about two hours. Nonetheless, it might be good to have one of these TVs for emergencies. Here's the link to this TV on Radio Shack's web site:
http://www.radioshack.com/product/index.jsp?productId=2855063
There are some interesting things going with the transition to digital TV.
1. Most stations that were on TV Channels 2 through 6 are being moved to higher-numbered channels. In the Indianapolis market, WTTV 4 is moving to 48 and WRTV 6 is moving to 25. There are some markets that will still have digital TV broadcasters on channels 2 through 6, but they are rare.
2. Most stations got digital licenses on different channels than their analog channels. In the Indianapolis market, 4 goes to 48, 6 goes to 25, 8 goes to 9, 20 goes to 21, 59 goes to 45, etc. The one anomoly is WTHR 13. Their digital broadcast is currently on TV Channel 46, but after February 2009, they will switch their digital broadcast back to TV Channel 13.
So, if anybody tries to tell you that you only need a UHF antenna to pick up digital TV, they are wrong. In the Indianapolis market, you will still need a antenna that works on the high-VHF band so you can get 9 and 13.
W9NES
.You will need a outside antenna, or a pair of rabbit ears which work fine for DTV and a DTV Converter box.If you are on cable(Comcast,Brighthouse, etc) you will be fine.If you are on sat tv you will be fine.If you are getting signals currently with a analog tv set on February 17,2009 at 12Midnight all tv stations across the US as per the FCC mandate will turn the analog signal off.The FCC was in town a couple of weeks ago and there was a interview done iin the local media.The FCC media relations person said the quote"19% of people in the Indianapolis market will not be ready when this happens" So make sure you are ready with Cable, Sat tv or have a DTV converter box on top of you tv set so you will not be left out or you will not get any signals on your currrent tv set.All tv stations are currenlty transmitting in both analog and Digital.If you have a DTV Converter box or a HDTV with a built in turner you will see they are Example Ch 6= 6.1,6.2 Ch 8= 8.1-8.3 ch 13=13.1,13.2, ch20-20.1-20.3 Ch 23=23.1 ch 40=40.1,40.2 ch42=42.1-42.5 Ch 59 =59.1 Ch 63= 63.1-63.4 Ch 69=69.1
enki042000
Lafayette,IN
That's alot of great info.The freqs I was lookin for were for the live feeds and that.Sorry bout that.We got a lot of good info about the dig freqs though.Thanx guys.
W9NES
If you want live frequencies try searching between 450.00-450.999 and also try 161.6-161.800.Also if you wish to watch live video by the Internet go to "Live Newscameras.com and you will be able to see live coverage from other tv stations across the county and all over the world.Hope this helps you out.If you need any further help please feel free to pm me or e-mail me at W9nes@Comcast.net. My door is "Always open"Best Requards, Tim DeLong W9NES Indianapolis NW side
enki042000
Lafayette,IN
Thanx.When I put those freqs in, my radio rounds them up to 450.98125 and 455.98125.I have an RS Pro 96 scanner.I also made sure the bank I loaded the freqs in wasn't set in MO mode.
W9NES
No Mick[ they are not data signals] If you will scan 450.000-450.999 like 450.250, 450.750, 450.2125, etc these are voice and they are newsbase to mobile frequencies and you will hear all the talk behind the scenes before they go live on the air.I also hear the Newscopters talking with there stations base getting directions from the newsdesk telling them where to go to cover breaking news from the air or on the street.All you have to do is LISTEN and you will hear what frequencies are voice and which ones are data.Also[ 123.025 VHF on the am aircraft ] is used for communications between all the newscopters in the Metro Indianapolis area during rush hour in the morning 5-7AM and also anytime there is breaking news while they are in the air.
Mick
Western U.S.
I did not know that 450.98 was other than voice. That's all I've ever heard, especially in the L.A. and San Diego area. What ctcss are you able to hear on 450.98 MHz? Thanks in advance.
Here's a list I put together for Sacramento:
http://www.radioreference.com/forums/showthread.php?p=177396#post177396
Here's a list I put together for Salt Lake City:
http://www.radioreference.com/forums/showthread.php?p=178999#post178999
W9NES
Yes I will agree that the frequency for WLFI TVch 18 "Newsbase" is on 161.760 with 100 watts and they are located at 2605 Yeager Road,West Lafayette,Indiana .WLFI TV ch 18 is owned by the same company that owns WISH TV CBS 8 in Indianapolis.All the programming is done from Indianapolis via Microwave link from 1950 N Merdian Street in downtown Indianapolis to there transmitter in West Lafayette.The Newscast are live from the Studio in West Lafayette but the other programming is done from Indianapolis to West Lafayette by Microwave link....Everything is controled from Indianapolis. Lin Broadcasting Owns WLFI TV CBS 18,Lafayette, WISH CBS 8 Indianapolis and WTHI CBS 10 in Terre Haute
