Twitter Dispatches
it be cooler if we could see the entire dispatch (the what and where, not just the who)
w8fsm
Fenton MI
well when u click the little link attached to it.. you hear the real call...
Unless you have some fancy text to speech program that can take the incoming emailed mp3 and do it's magic and pop it back out as text Id like to see it...
Kool, its even better being able to hear it. :)
johnvassel
Near Lansing, Michigan
Thanks to seeing Fred Moses implement this - I've added fire dispatches for Delta Township and Lansing Township to Twitter.
(lansingtwpfire) on Twitter
(deltatwpfire) on Twitter
Twitter / @netsound/Moses Tweets
Just dropping back into the forums after some time, Rob, is there a tutorial somewhere on how to setup a twitter feed like these? I checked Freds tittwer (only about 2 layers deep) and didn't find it.
I'll search on here, but thought I'd ask whilest I searched :)
