Two Dongles or one?
PA
#2
Monitoring trunked systems can be done with a single dongle, but it works much better with 2. Spend an extra $20.
#3
I use two dongles, Unitrunker and DSD+ to monitor the EBRCS system in the SF Bay Area. I think the quality is as good as my PRO 668. I've heard it can be done with one dongle but for another $20, it wasn't worth the hassle.
boatbod
Talbot Co, MD
#5
All depends what software you plan to use. OP25 only uses a single dongle. Most of the others can use multiple devices.
