HOGMOA
Can two scanners use the same external antenna? Thanks, Frank
And what would I shop for. Not really good at thisThe best way is to use an amplified multi-coupler so there is no loss. Ordinary splitters will result in a loss of signal,
You'll need one of these.And what would I shop for. Not really good at this
I picked Passive Multicouplers HF to UHF - 2 and 4 ports (signal splitter/combiner) for my primary interest in Civilian/Military Aircraft Bands. I am coming from a Disc Cone Antenna by 25 Foot UHF PL259 Male to BNC Male LMR400 Times Microwave 50 Ohm Coax Low Loss Antenna Cable. That comes in the house to where I will be putting the splitter. The incoming connection is BNC and I will need a few feet of Coax to the two radios. Do you have a suggestion or source of where I can get those two short pieces of Coax and what kind I should use?You'll need one of these.![]()
STRIDSBERG
Pay attention to the cables you need from the multi coupler to the scanner and order the coupler correct.. I needed all BNC stuff.
Not sure why it did that. I have 2 BNC to BNC 3' LMR 200 cables. I get my cables from Antenna Farm.I picked Passive Multicouplers HF to UHF - 2 and 4 ports (signal splitter/combiner) for my primary interest in Civilian/Military Aircraft Bands. I am coming from a Disc Cone Antenna by 25 Foot UHF PL259 Male to BNC Male LMR400 Times Microwave 50 Ohm Coax Low Loss Antenna Cable. That comes in the house to where I will be putting the splitter. The incoming connection is BNC and I will need a few feet of Coax to the two radios. Do you have a suggestion or source of where I can get those two short pieces of Coax and what kind I should use?
+1 for Antenna FarmI get my cables from Antenna Farm.
