Two Tone Detect down?
Asmitty0010
New Hampshire
i have been using this for years with no issues. This week it has stopped sending emails. I can't send an admin email either. Is anybody else having trouble with this?
thanks
fredva
Virginia/West Virginia
Yes, just noticed that I didn't get emails that should have been sent out last night. I'm using version 6.3 and the gmail smtp server with its TLS port.
Asmitty0010
New Hampshire
timeline seems right. Thanks for this info. Comfirming the emails need to be sent by a non google email?
Thanks again
pj226
Port Dover
I have tried to use Proton mail but not sure how to use it in TTD. I have also tried the app password but don't understand what " then used the base 64 converter and updated my config file with that. " means.
Mex
Surrounded by cornfields
Do you have a subscription with proton mail? You can only use proton SMTP if you subscribed to the Plus or Ulimited plan. https://proton.me/pricing?product=mail
nhfdcadet
CETsr
New Hartford, Ct
I had the same problem. It wasn't limited to gmail either, I made a mail.com address, didn't work, and a yahoo.com address, and that didn't work either.
I was able to do it with the app password from gmail though for some reason the second time I tried
pj226
Port Dover
I will try the app password again. I’m still having an issue getting proton mail to work.
Mex
I shouldve mentioned you should use the smtp hostname not the imap hostname. Also double check if smtp is enabled in your protonmail account settings
pj226
Port Dover
I have no idea what I am doing wrong. I have everything working with protonmail. I did the bridge and it is working, I added it to my outlook, it still works. TTD will still not send out the emails. I have given up on app password as I do not understand how to set it up. just doesn't make sence to me.
Mex
Did you change the email settings to match the pronton email account settings?
onsceno
New Jersey
I'm running TwoToneDetect70 and, like everyone else, ran into the same "non-email/paging" issue. Now... if I'm reading all this correctly, I made sure the app password thing was taken care of and originally updated the password in the config file to what the app password is - no go. Flipped it back to the original one - still no go. The error line I'm getting is:
Traceback (most recent call last):
File "TTD70.py", line 82, in mail
File "smtplib.py", line 622, in login
SMTPAuthenticationError: (535, '5.7.8 Username and Password not accepted. Learn more at\n5.7.8 Check Gmail through other email platforms - Gmail Help m187-20020a37a3c4000000b006a75a8fd54asm6983711qke.84 - gsmtp')
Email not sent via smtp.gmail.com on port 587 using STARTTLS on attempt 3 trying again in five seconds for Sidney EMS [24] Page Received at 17:23:35 on 06/26/22
What am I doing wrong??
