Ryolsen8,
Any chance you are trying to run it a second time while it is running in the background?
Sent from my iPad using Tapatalk
I don't believe it is..
Ryolsen8,
Now I have usb card working and got the audio to low. How do I turn it back up. I have tried the microphone setting and it does not seem to help.
Got any more suggestions it did not move. I know I am getting audio to the computer because it is live feed and I can hear it when I key the mic.
I turned the speakers up, I turned up the volume on the usb card, I went in to the audio control and turned them up, I noticed that after I went in to the radio feed program and got it to working that is when my audio went down to nothing on my Two Tone Detect software. I am attaching a screenshot of this for you to look at.
I checked the cord that sends the audio from scanner to usb card and it was working.
I will check this and get back with you Thanks
Well it has stopped doing it, nothing changed after we changed the email password and it has worked great. Thanks anyway I do appropriate itCan you post pictures and logs?
Has anyone got this running on Ubuntu server?
It will run on ubuntu desktop, but I'm not sure that the server version will support it... I would think audio drivers would be an issue at the lest
Download it unzip it to a folder I usually go with on my desktop, open the folder and you have all the executable files, use the tones editor to place the ones you need save and exit the run the twotonedetect70 configure the settings and you should be up and running,How would I go about running in from desktop version?
