Type of antenna connection?
LtDoc
Oklahoma
Looks like a typical 'stud' mount. Several mounts use those type 'studs'. The one that comes to mind first is a 'ball-mount'. I kind'a doubt if that's what was used, but I think you get the idea.
- 'Doc
Rt169Radio
CT
Thanks for the replys.What kind of mag-mount would be able to use this kind of antenna and where could I find some?
Rt169Radio
CT
There are two different NMO 150 mounts,which one would be the best?
KG4INW
Midlothian, VA
Sorry, should have clarified! Depends on whether the whip you have is currently cut for 5/8 wave or 1/2 wave. How long is it?
According to my cutting chart, at 146 MHz, a 1/2 wave whip should be 40 1/8" long and for a 5/8 wave at the same frequency, it should be about 48" long.
