Hey guys,
I'm hoping you guys can help me. I have a tyt 9000d radio that I am trying to program through the computer but i am running into a big problem when trying program DCS codes. I have tried using both CHIRP and the programming software that comes with the radio.
The problem is that whenever I try to program a dcs code it does not store correctly on the radio. for instance if i try to write DCS code 466N the radio will be programmed as 066N. Every single DCS code is written to the radio exactly 400 codes lower than it should be. no matter what i do I can not seem to get this to write the correct codes.
Has anyone else dealt with this issue. I have tried doing a factory reset and rewriting the frequency list and this has not helped.
PLEASE HELP!
PLEASE HELP!
