Kb2Jpd
You cannot be serious - every time you want to programme a radio you need a fresh install of the OS? Totally crazy.
The USB serial chips are sending tiny amounts of data on an ancient protocol that doesn't stretch a computer whatsoever! The issues with the ability to programme the radios are simply because the Usb to serial conversion is usually done on a very cheap IC that mimics the operation of the original one. Things have moved on with the original, and the drivers most of these Chinese radios are using is very dated, and the modern versions of Windows detect the driver is nowhere near the latest one, and replace it from the driver database - assuming that the latest one is the best one. The updated driver is fine on the latest genuine chip, but very flaky on the copies based on the very old versions. Using a separate computer to programme radios is what many of us do simply because of the hassle with windows 7,8 and 10. A new install of Windows is a simply ludicrous solution to poorly produced chips and old drivers. I dedicated a computer to radios simply because I had an old laptop laying around - but I can use another older Vista computer with loads of stuff on it perfectly, no need for a new OS. My other computers just hate programming some radios - My Icons and Kenwoods are fine on Windows any version. Kirisun works on most, TYT on about half and the few counterfeit Kenwoods I bought by mistake only work on two of the computers - XP and Vista. I can force windows 8 to load the legacy driver and then it works, but on next boot up, it puts the newer one back. The Baofengs are all a bit different - all work with the old computers, but even messing with drivers is unreliable with the 888s, ok on the 5s.
Is it more like you are too lazy just to make a bootable usb drive, do the OS install on it, add the programming software, label it for the radio you desire, then put it in a safe place along with the USB programming cable.
If you want people to read your posts, keep it short and sweet, you sound like a 80 meter windbag .
