Hello all, I have a strange TYT MD-UV380 issue, looking to see if anyone has seen this or has advice.
I got the radio from a friend who was frustrated that it was not working. It is a later "V" firmware model, but it's still pretty old.
Anyway, after much testing, I found that the programming was not controlling the frequency correctly. No mater how you program it, it will only transmit on 150mhz VHF or 450mhz UHF. Even with trying to wipe the code plug, update the firmware, etc. same behavior. I have another base station I tested with and no matter the programming, it will only Tx/Rx on 150/450mhz; very odd. However, using 450mhz, I was able to play with pi-star and DMR; it all seemed to work very well with brandmeister right from the start.
I loaded openGD77 (following all directions, donor firmware, 16mb firmware backup, etc.) and I get different behavior. Now the analog side seems to work as expected (I hit all my local repeaters), but now DMR does not. I've verified that it's transmitting something that sounds like DMR, but the pi-star doesn't recognize the DMR packets (doesn't even log anything). The Green Rx LED on my baofang 1701 lights up, but it refuses to recognize the DMR and decode the audio. The UV380 will pick up traffic from the pi-star and simplex from the 1701, but the UV380 Tx seems to have some kind of problem. I played with timeslots, frequencies, color codes, etc. no luck. The only thing I haven't figured out yet is if I can put my 1701 in some kind of promiscuous mode to receive all DMR to check if the UV transmits any sensible. I was able to revert the UV380 back to the stock firmware, and it reverts back to the old 150/450mhz limited behavior with DMR working.
So I'm just fishing around to see if anyone ever saw something similar or had any advice on how to troubleshoot.
Any suggestions? I'd prefer to have this working in openGD77/DMR mode even if analog doesn't work.
Thanks!
Thanks!
