TYT MD390 problem
kb9hgi
IL
#1
I have a TYT MD 390 with GPS I bought it off ebay in OCt 22nd. I had it on charge and then took it off and turned it on and it powered up with screen then all of a sudden the screen went white. It still works and is programmed but when you turn it on all you get is a white screen and you cant see nothing or tell what group your on. Anyone else had this problem with this radio and is there a fix or is the screen shot after 3 months and only been used a couple times. Can it be fixed or throw in trash?
PALM BEACH, FLORIDA
#2
TYT has a wonderful customer service team. Since the radio is barely 2 months old, I would call them right away to make arrangements for them to repair the radio under warranty.
dsalomon
Brooks, GA
#3
I had the same thing happen to mine 2 days after I received it. Tyt's warranty support is good. They should exchange it with no issues. All they asked me to do was send them a short video of the white screen showing the problem. Once they saw it, they sent an RMA. You will have to pay return postage.
#4
My MD390 suddenly had a problem that never experienced before. As soon as I turned on the radio the display automatically switched to Menu but the keypad was basically dead and there is no response keying up any numeric and functional key. Only thing worked is the side button programmed for H L power switch.
I have tried to upgrade the FW to the latest version as well as flashing again the MD380Tools yet no progress to close this.
Any advice is appreciated.
Kim
