Tytera TYT UV-380, Extending Frequency Range
top13
SE Massachusetts
Hi all, I purchased a TYT UV-380 to use as a scanner.
Is there a code plug or another way to expand the frequency range from 480 to 490?
Many local police and fire use this range. I find that transceivers receive much better than wideband scanners.
Thanks Much
n0xvz
Member (barely)
San Angelo, TX
The specs for the radio list the UHF band as 400-480MHz. Just for kicks, I tried putting in a frequency outside of that to see if the CPS would take it. Nope.
A better option would be to use the right tool for the job. Some scanners would do better for you.
top13
SE Massachusetts
Thanks for responding.. I tried the out of band frequency also, same results as you.
I have numerous scanners up to P25 phase 2 and DMR. As base radios I use an Icom IC-208H, Locomotive radio, marine radios and a Vertex 6000L. They all receive better than the scanners. Thanks
