Tytera (TYT) UV-8200 Radio - Flexible Antenna?
teward
Pennsylvania, USA
A client of mine was kind enough to donate a handful of TYT UV-8200 IP67 waterproof radios to me and the two other consultants whom I work with for use on some of my other clients' radio systems (I do consulting in the IT world, and some of my clients have offices that span about three square miles of space and distance, so they have radio networks set up, and allow me to use their radio systems when working on-site).
Like my Baofeng radios, this radio came with a shorter (about an inch shorter than the Nagoya 701Cs on my baofengs) but less flexible antenna. This is all fine and dandy, but I need to make sure that I have an antenna on this that is about as long but less prone to being broken. It also came with a very long, flexible antenna, which is far longer than I can use when carrying the radio around on my hip when working at clients' sites.
I'm hoping that, once again, the RR community here can provide me with decent guidance on a similar-length, flexible antenna for my SMA-Male TYT UV-8200 radio. Any suggestions? (Preferably ones that work well with the waterproofed nature of this radio?)
(And yes, I have 4 radios of my own in total, three Baoeng UV-5Rs of which two are connected to a Surecom repeater controller so I have a portable GMRS repeater station, and this TYT UV-8200... is this too much of a collection? :p)
If it's relevant, the places I work with these radios are all in the UHF ranges, with the exception of the one VHF frequency I occasionally listen to when my Whistler TRX-1 scanner needs charging or if I forgot it at home - the NOAA Weather Radio frequencies)
16b
Central Ohio
If all you need is UHF, then a Kenwood KRA-27 antenna would be a good choice. They are intended for Kenwood commercial UHF radios, but since the antenna connector is the same, one should work fine on your Tytera. They are flexible, durable, high quality antennas. Just watch out on eBay--there are a lot of counterfeits from China.
You can use a UHF antenna to receive VHF signals; it will just not pick up as well as a VHF or dual band antenna. For NOAA weather radio, it would probably work fine unless you are in a fringe area. Just don't transmit on VHF; that could damage your radio.
teward
Pennsylvania, USA
Thanks for your recommendation! I'm always looking to prevent damage to my radios, and it's also a high chance that at *some* point I'll need VHF. (And don't worry about eBay, I usually use legitimate sellers on Amazon instead of using eBay, unless I am hunting certain types of equipment that Amazon doesn't carry, and I'm very peculiar about how I do eBay purchases heh).
Along the same lines of recommendation, do you have a good recommendation for dual-band antennas for this radio, in the off-chance I needed to broadcast on VHF at some point in the future, in addition to the UHF? (It lets me pick up 162.55 either way, mind you, but if I can make sure to get an antenna that works better, that'd be great, and prepare for the future if I ever need to use VHF; most of my clients have narrow-band UHF radios but I can't preclude the possibility one will have VHF, heh)
teward
Pennsylvania, USA
I've never used any aftermarket dual band antennas on my Chinese radios, but Nagoya seems to get a lot of recommendations. If I were going to buy one, I'd probably get this:
https://www.amazon.com/gp/product/B...ativeASIN=B01AX3AYOK&linkCode=as2&tag=btek-20
Funny you provide a link to that item, that's the same antenna on my Baofeng UV-5R radios which I purchased after-market. This, however, uses an SMA-Female connector; I need an SMA-Male antenna. (Though I suppose I can find a gender converter to make the SMA-Female antenna have an attached SMA-Male connector which can work with my Tytera radios now)
