UASD Files needed for the 396T
n4yek
Newport, Tennessee
Anyone have UASD files for the Jacksonville and St. Augustine areas?
I will be coming down there in June, as I do every year, but I now have
a new scanner.
PM me if you do and will share them.
Thanks for taking a moment to read this thread.
UFEMTFF
Arlington, VA
Well I'd like to help you but...
1. I have the 996T, so I don't know if that'll help and
2. I don't know which file to upload. Where can I find it?
I've attached my "layout". Basically a frequency or channel is named A.B.C where A= System, B= Group C= Frequency. I have this cheat sheet printed out so whenever I need to lock or unlock something I can do it easily.
EDIT: They're saved in my documents. I can upload all the systems (9 different files) if you'd like, but again, I don't know if 996 files will work with the 396.
n4yek
Newport, Tennessee
I noticed when it started the program, it wanted to save files in the 'Documents and settings' folder. I would look in there for the 'BCD396T' folder then look for a folder named 'UASD_systems'. There is where is save the configuration files for your programmed frequencies. Even if it doesn't totally work, I can the info from the files by loading them into 'notepad' and opening it up that way.
If you get them, PM me and I will give you my e-mail address to send them.
Thanks for your help.
EDIT: I sent you a PM, UFEMTFF
