UBC3500XLT, 2500 channel max (but 40% free mem)
elsinga
Sintjohannesga, the Netherlands
Hello,
When I loaded my 3500XLT with almost 2500 channels it was 58% filled according to the settings menu. So I tried to upload over 4000 channels (extrapolating 2500 at 58% to over 4000 at 100%). ;)
bctool stopped at 3961 channels, so I tried reading them back. I got to exactly 2500 channels and a lot of empty systems. So it seems Uniden programmed a hard limit of 2500 channels in the formware, although dynamically I could fit almost 4000 channels in the scanner...
Why? I know they want to make sure users arent's expecting too much, but this is a bit over the top IMHO. I know the memory is dynamic, so shorter channel tags creates space for more channels IN THEORY. The 2500 channel limit seems to be based on a worst case scenario... I have on average over 4590 channels in my database a 8.5 character tag. But I get no return on that "investment"...
Could Uniden make it possible to use the memory to it's fullest dynamic size? I wouldn't mind checking a "advanced memory use" setting, which warns me of corruption and the like...
UPMan
In Memoriam
Arlington, TX
The other portion of memory is required for other settings (search frequency lockouts, for example). The 58% reported number is a composite of all the limits in the scanner. 2500 is the "hard limit" for maximum channels and represents all the memory available for channels.
elsinga
@UPman: thanks for the clarification. Strange that the 3500XLT accepted up to 3916 channels before it started rejecting them.
I ran into a strange side-effect of this upload (I think): a lot of Group Quick Keys were disabled all of a sudden and not even a reset would re-enable them and Func-number didn't work either. So I needed to hold L/O on each blocked group to unlock it. Well, glad that at least that worked. :)
