UCA Modifications to emissions on existing Licenses
enosjones
Price, Utah
https://wireless2.fcc.gov/UlsEntry/attachments/attachmentViewRD.jsp;ATTACHMENTS=RkdydDPNYbsMsDGGs287G3wGJcJXFwlRPcLQ9v3PrnTGhhpJzdJX!-2129894487!-423534557?applType=search&fileKey=1986353313&attachmentKey=20614499&attachmentInd=applAttach
as of Today the Barton Peak WQGN760 Modification for emissions
These Changes Reflect that UCA is modifying licenses for Phase ii there are 16 total Licenses in this pdf letter, 2 just granted today on fcc
05/24/2019 Location 1, Antenna 1, Frequency 00856.43750, EMISSION 21:Emission Designator added 8K00F1D 05/24/2019 Location 1, Antenna 1, Frequency 00856.43750, EMISSION 22:Emission Designator added 8K00F1E 05/24/2019 Location 1, Antenna 1, Frequency 00856.43750, EMISSION 23:Emission Designator added 9K80D7W 05/24/2019 Location 1, Antenna 1, Frequency 00857.43750, EMISSION 24:Emission Designator added 8K00F1D 05/24/2019 Location 1, Antenna 1, Frequency 00857.43750, EMISSION 25:Emission Designator added 8K00F1E 05/24/2019 Location 1, Antenna 1, Frequency 00857.43750, EMISSION 26:Emission Designator added 9K80D7W 05/24/2019 Location 1, Antenna 1, Frequency 00858.43750, EMISSION 27:Emission Designator added 8K00F1D 05/24/2019 Location 1, Antenna 1, Frequency 00858.43750, EMISSION 28:Emission Designator added 8K00F1E 05/24/2019 Location 1, Antenna 1, Frequency 00858.43750, EMISSION 29:Emission Designator added 9K80D7W 05/24/2019 Location 1, Antenna 1, Frequency 00859.43750, EMISSION 30:Emission Designator added 8K00F1D 05/24/2019 Location 1, Antenna 1, Frequency 00859.43750, EMISSION 31:Emission Designator added 8K00F1E 05/24/2019 Location 1, Antenna 1, Frequency 00859.43750, EMISSION 32:Emission Designator added 9K80D7W 05/24/2019 Location 1, Antenna 1, Frequency 00859.76250, EMISSION 33:Emission Designator added 8K00F1D 05/24/2019 Location 1, Antenna 1, Frequency 00859.76250, EMISSION 34:Emission Designator added 8K00F1E 05/24/2019 Location 1, Antenna 1, Frequency 00859.76250, EMISSION 35:Emission Designator added 9K80D7W
Application Status A - A Granted
Effective 06/13/2019
and also License WQED590 also Barton Peak
05/24/2019 Location 1, Antenna 1, Frequency 00851.10000, EMISSION 3:Emission Designator added 8K00F1D 05/24/2019 Location 1, Antenna 1, Frequency 00851.10000, EMISSION 4:Emission Designator added 8K00F1E
05/24/2019 Location 1, Antenna 1, Frequency 00851.10000, EMISSION 5:Emission Designator added 9K80D7W 05/24/2019 Location 1, Antenna 1, Frequency 00851.55000, EMISSION 6:Emission Designator added 8K00F1D 05/24/2019 Location 1, Antenna 1, Frequency 00851.55000, EMISSION 7:Emission Designator added 8K00F1E
05/24/2019 Location 1, Antenna 1, Frequency 00851.55000, EMISSION 8:Emission Designator added 9K80D7W 05/24/2019 Location 1, Antenna 1, Frequency 00853.72500, EMISSION 9:Emission Designator added 8K00F1D 05/24/2019 Location 1, Antenna 1, Frequency 00853.72500, EMISSION 10:Emission Designator added 8K00F1E 05/24/2019 Location 1, Antenna 1, Frequency 00853.72500, EMISSION 11:Emission Designator added 9K80D7W
WQED590 Application Status A - A Granted General InformationApplication Purpose MD - Modification Existing Radio Service Authorization Type Regular Emergency STA Receipt Date 05/24/2019 Action Date 06/13/2019 Entered Date 05/24/2019
enosjones
Price, Utah
9K80D7WP25 Phase II fixed-end 2-slot TDMA (Harmonized Differential Quadrature Phase Shift Keyed modulation – H-DQPSK), per Motorola literature
7K60FXD 2-slot DMR (Motorola MOTOTRBO) TDMA data 7K60FXE2-slot DMR (Motorola MOTOTRBO) TDMA voice
8K10F1D P25 Phase I C4FM data 8K10F1EP25 Phase I C4FM voice (P25 mode in RadioReference.com Database)
8K10F1W P25 Phase II subscriber units (Harmonized Continuous Phase Modulation – H-CPM)
8K30F1D NXDN 12.5 kHz data (Wide IDAS, NEXEDGE)
8K30F1E NXDN 12.5 kHz digital voice (Wide IDAS, NEXEDGE)
8K30F1W P25 Phase I C4FM hybridized voice and data applications (most commonly seen on trunked licenses)
8K30F7W NXDN 12.5 kHz digital voice and data (Wide IDAS, NEXEDGE)
8K50F9W Harris OpenSky (2 slot narrowband)
8K70D1W P25 Linear Simulcast Modulation ASTRO (9.6 kbps in 12.5 kHz channelspace)
9K20F2D Zetron-based alphanumeric paging/alerting system (seen in practice using Daniels base stations)
9K30F1D SCADA/ Remote Control
9K36F7W Yaesu System Fusion C4FM (Voice Wide * Voice Narrow + Data * Data Wide)
9K70F1D P25 Linear Simulcast Modulation “WCQPSK” data (per Harris MASTR-V literature)
9K70F1E P25 Linear Simulcast Modulation “WCQPSK” voice (per Harris MASTR-V literature)
9K80D7W P25 Phase II fixed-end 2-slot TDMA (Harmonized Differential Quadrature Phase Shift Keyed modulation – H-DQPSK), per Motorola literature
9K80F1D P25 Phase II fixed-end 2-slot TDMA H-DQPSK data, per Harris MASTR-V literature
9K80F1E P25 Phase II fixed-end 2-slot TDMA H-DQPSK voice (interpolation of MASTR-V literature)
enosjones
Price, Utah
NPSPAC Region 41 800 MHz Frequency Review Committee c/o Utah Communications Authority 5215 Wiley Post Way, Suite 550 Salt Lake City, Utah 84116
From the PDF
May 21, 2019
Federal Communications Commission Washington DC 20554
To whom it may concern:
This letter serves as official notification and written concurrence that the Region 41 NPSPAC Frequency Review Committee approves the modification to the following existing licenses belonging to the Utah Communications Authority as listed below. All licenses will be modified to include the emission designators of 8K00F1D, 8K00F1E, and 9K80D7W.
KNIV722 WPRI840 WQAP756 WQED590 WQED620 WQED636 WQED653 WQED664 WQGN760 WQGR274 WQKZ444 WQLB510 WQOI294 WQXX543 WRAU588
Region 41 has reviewed the provided information and finds that there will be no adverse interference caused by the addition of these emission designators and provides this letter of concurrence for licensing.
Sincerely,
Harold C. Clements NPSPAC Region 41 Chairman
kc7rhw
Roy
so when are we going to p25 phase DTMA full time . and will i need to up grade to NEXEDGE
enosjones
Price, Utah
I don't know but I don't think you will need nexedge unless you go to carbon or Emery counties , u may just need a phase II scanner at least for UCA, there was some talk of phase II being implemented by the end of 2020, but as large as UCA is and all the radios that need programmed and changed I'm not sure if that's possible...
Sent from my iPod touch using Tapatalk
dlaforett
midvale, utah
I know salt lake city has been making modifications for the last 4 years they all have the new Motorola xps radios upgraded tower sites
