UCAN TG "Birdies"
North Central Utah (UtCo)
I've been out of the scanning hobby for 18 - 24 months, but now wanting to get back into it...
I've noticed when scanning the Utah County multicast that certain talkgroups will "stick." No communication can be heard and it appears to be the same few talkgroups. Just to confirm whether it was a particular radio, I tried two different units and both would stop on the same talkgroup at that moment with no sound coming from either. It isn't only one talkgroup but both radios stop on the same at the same time.
I'm wondering if you all are experiencing the same issue or am I just in a noisy interference location?
Thank you.
kc7rhw
Roy
ucan
are you listen while in trunk mode all of ucan u have to be in trunking mode
if you listen to the 800 the old way then you will get lock up you all so have to have a scanner
that can handle the rebanded freq. old scanners can not trunk you did not tell us which mode you are in
