Uhf p7100ip
xml
mitaux8030
Silent Key
Home
You're out of luck. Pers Ver 50 means it was programmed with, and requires RPM, not programmer. There is a process of reflashing the radio so it can be used with programmer, but you need a file from RPM to achieve that.
davidbond21
New Braunfels, TX
OT, but check out this line out of the sellers description:
I am selling these for my police department as we are trying to collect enough funds to purchase dated equipment that our city can't afford.
Jaded much?
xml
I have a few repeaters I can use it on. But yeah, this buyer looks a little sketchy.
If anyone has one they want to sell, let me know!
Thanks!
ElroyJetson
This may be one of the ones that has no feature data in it. A bunch got lost in shipping and an unclaimed freight reseller got them and started selling them. M/A-Com will have nothing to do with them and will not assign even a basic feature string to them. Buyer beware.
Do not buy them without proof that they have valid feature data and show no errors.
Elroy
Radioman96p71
I would offer them 100 bucks and tell them thats the best they will get, without features and in that bandplan they are good for the case and other parts at most.
MR-EDACS
Florida
Well I have one that I use. But the battery life sucks on these radios so I stick to my MRK radio. You want P25 operation then I would go with the XTS 2500 or 5000. Just a thought
Z0_RICK
A properly conditioned 700p/jaguar type batt (THIS IS THE P7100))/7150/P7170 TYPE)should go around 10 hrs. If it does not you have an old batt or a bad radio. We have hundreds in our fleet and a good batt will last all day with normal use. These radios are extremely durable as well,
ElroyJetson
I have a VHF P7100IP as well as VHF Motorola radios of every top end type made in the last 20 years. I am quite able to compare their operation and performance and frankly, the only reason I have to use the P7100 at all is because the RSSI and signal strength displays in the FCC menu are incredibly handy tools to have on hand when mapping out the coverage of a repeater system or attempting to locate a stuck transmitter.
Frankly, the most I can say for the P7100 in other respects is that it is a workable radio. It excels at NOTHING. It's not very well made, it's not particularly rugged, and I'd never, ever trust the weather sealing on it. It's pretty cheaply made, using a construction method that is at least 10 years outdated.
Its audio quality is really poor for such an expensive radio, its transmitter is inefficient, losing almost half the actual transmit output power in the TX/RX filter module, and its receiver is sensititive but not very resistant to interference.
I'd take a good condition regular Motorola Saber before one of these, if the Saber served the purpose at hand. Any newer Motorola radio is in another class of quality entirely.
Elroy
2wayfreq
NM Kirk City
I like the M-RKs too. But trying to find a decent V or U Split (Not 403-433) on E-Bay is like trying to find hens teeth. Why are these things so scarce? You would figure that they made a bung load of these.
