UHF talk to VHF
rce149
Macon,ga
Was wondering if you could hook up a up VHF NEXEDGE repeater to a to a UHF NEXEDGE repeater in a wide area ip network and have both repeaters TX so UHF users and VHF users can speak to each other without changing channels.
b7spectra
EMS Dispatcher
Cobb County, GA
I know that with Motorola equipment, you can "patch" together talk groups so they can talk to each other. Example - in the Metro Atlanta area, the Dobbins RAFB has a 400MHz DTRS and it can be patched together with the Cobb County DTRS and the two can talk to each other.
Av8tor56
Roswell, NM
If you're going to use an IP based system you can check out BridgeCom. They make an IP based interface that can network repeaters and also allow you to cross-band. We tested one with a tech at BridgeCom and talked via a UHF portable in New Mexico to BridgCom's office in Missouri.
lbfd09
California
Normally one can intertie multiple repeater together with the help of a repeater controler.
Detail infor on repeater ops can be found on the RepeaterBuilder.com site.
