UHF to VHF Repeater
KD2GMJ
I think I saw something about this before but I can't find it so I figured I'd ask again. I'm looking to build (preferably using 2 handheld radios) a repeater that will repeat from a VHF radio to UHF. Is this possible? Is there a way to connect 2 radios together in this fashion? I'm definitely willing to build something clever to do this, or if there's already something to purchase, that works too! Thanks!
-Danny
KI4UIW
-Danny
all you need is a repeater to do this. We use repeaters in ham radio to do this.
n5ims
-Danny
Quite easy to do. Many of the current crop of dual band mobile ham radios have a cross-band repeat function built in. Nothing to build, just change the settings to configure and activate it. If you must have a handheld, the choice is quite small. A few older ones had it, but generally this feature isn't put onto a handheld.
If you must build it yourself using 2 handhelds, check out this thread that discusses that topic --> http://forums.radioreference.com/amateur-radio-general-discussion/192857-building-repeater.html
davidgcet
for mobile any regular moto repeater controller, such as used in the GR300/500 series repeaters will work. it does not care what freq the 2 units are. you won't be able to use a duplexer, so you will need 2 antennas. you can even make it repeat BOTH ways by positioning jumpers or programming, depending on which controller you get.
for portables it will be a little more challenging since they usually have limited I/O capabilities. plus they will not have any real range, maybe a mile or two.
