ProScan: UID Loggin data program to Scanner
sidthekid1998
brossard,quebec,canada
I've been using the proscan UID logging function and saved many UID's... but the dont seem to be added to the database, how can I add the UID'S i save to my BCD436
ProScan
Software Provider
Ontario, Calif.
Did you click the button "Copy/Move Selected Rows To UID Lookup, Database, or Other File"?
ProScan
Software Provider
Ontario, Calif.
You do not need to enter them in manually.
Steps are:
1. Insure the Favorites Editor appears and a Favorites file is opened.
2. Select the rows of UID to be copied or moved.
3. Click the button "Copy/Move Selected Rows To UID Lookup, Database, or Other File"
4. When the dialog comes up, choose Database then select the Favorite & System from the list then click the OK button.
5. The UIDs should now appear in a Favorite list & System.
6. Write to the scanner.
cg
Connecticut
If you run the scanner attached to a computer and using ProScan, you can view the IDs that are entered into the UID Lookup File. That file can be edited by hand or line by line as Bob described. If you want to see the IDs without the computer, then they must be entered into the scanner via software or by hand (huge pain in the butt for more than a couple IDs).
chris
