Sentinel: UIDs do not read from scanner
havmedic26
NH
During the course of the day, I will quick save UIDs on my SDS100. When I got home, I used the "Read from scanner" function on the sentinel software. None of the UIDs i added directly to the scanner showed up in sentinel. Do I need to select some option somewhere? Or does this just not work?
werinshades
Chicago , IL
Are you leaving the scanner on or shutting down and turning it back on and then attempting to Read from Scanner?
havmedic26
NH
I had turned it off when I got home. Then later turned it on and tried reading from scanner. The UIDs are still in the scanner, but not in the software.
werinshades
Chicago , IL
Did you select the Save to PC option when prompted for the system you saved them to?
havmedic26
NH
I figured it out. Thank you!!!
Longer answer:
I did. And I wanted to make 100% sure before I answered so I just did it again. They still weren't there. Then I realized that it appears as a different favorite list. Maybe I selected the wrong option. It was exactly what you said, but it was close. Whatever the top option was.
werinshades
Chicago , IL
Longer answer:
Glad it worked out, but yes has to be saved to the program under the matching favorite list.
havmedic26
NH
If you don't mind (because I appreciate your help already # Thank_You), can you tell me which option to select to update the existing list when I read from scanner? That would be preferable.
werinshades
Chicago , IL
What is the favorite list name that you're saving it too? (If that's the question?) When you do a Read From Scanner, the scanner will prompt you if you want to save a change correct?
